Creates a Web server XML-notification target name.
target_name | Specifies the name of a non-existing XML notification target. |
xml_target_name | Specifies the name of an already existing XML notification target. |
N/A.
Use this command to create a web server XML-notification target name for EMS.
The following command creates the target name test2:
create log target xml-notification text2
This command was first available in ExtremeXOS 12.4.
